DMG MORI Spindle Service
Because every spindle hour counts.
- More than 6,000 spindles immediately available worldwide, regardless of machine type and year of manufacture
 - Quality first – Whether replacement spindle or repair, we only use original spare parts
 - Prioritized processing – order spare parts around the clock with my DMG MORI
 - The choice is yours – Our express solutions for minimal downtimes or our more cost-effective Premium Spindle Repair
speedMASTER-K – Did you know?
If technically feasible, we upgrade your spindle to our speedMASTER-K for maximum service life. As a quality promise, we increase our warranty for the upgrade spindle:
- 18 months on renewed spindles
 - 36 months on all new spindles
New & replacement spindle service
Our Express-Solutions: New – or Replacement Spindle Service
Our spindle service employees can replace your defective spindle within 24 hours of the initial diagnosis. A professional spindle run-in will be carried out with requirement-based geometrical checks. It goes without saying that the DMG MORI Spindle Service includes additional balancing and a final acceptance.
Option 1 – New Spindles
- 18-month warranty on all new spindles
 - More spindle hours, more warranty – 36 months warranty on all MASTER spindles, including our new speedMASTER-K – with no limit on spindle hours!
 - Save additional costs: If necessary, we only replace the rotor!
Option 2 – Replacement Spindles
- Renewed spindles are up to 25% cheaper than new spindles
 - 12 months warranty
 - NEW Because we trust in our quality – 18 months warranty on all renewed MASTER spindles
 - Long-term reliability thanks to state-of-the-art replacement spindles and the exclusive use of original spare parts
Did you already know?
Over 50% of all spindle components are renewed and reused. With your sustainable "as-new spindle", you save resources and reduce waste products sustainably without compromising on quality.
Spindle Repair Service
Our low-cost alternatives
With our customised spindle repair service, you are always in control of your costs. After diagnosis of your defective spindle, our spindle service experts create an offer for you with our repair recommendation. Then you decide on the extent of the spindle repair. Now also for spindles from other manufacturers!
Option 3 – Premium Spindle repair
- 12-month warranty on replaced parts and work carried out
 - Spindle diagnosis within 1-2 working days of receipt of goods
 - Use of run-in parameters and cycles that are only available from the manufacturer
 - Professional installation of your spindle by DMG MORI service experts
 - For spindle repairs, the spindle is always rebuilt to the latest technical standard
MASTER spindles
Longer service life & more warranty. Our MASTER spindle variants.
Maximum service life for all MASTER spindles thanks to VACRODUR bearings.
NEW speedMASTER-K
Improved performance now also for older machines – With our new speedMASTER-K, machines from older model years can now also benefit from the durable VACRODUR spindle technology.
Our service experts will always check whether your spindles meet the technical requirements for retrofitting.
- No adaptation to the machine necessary – The spindle housing remains identical
 - Tool clamp with 5 million cycles service life and smooth spindle run
 - Maximum warranty – 36 months on all new spindles and 18 months on replacement spindles
 - Simplified repair and maintenance thanks to proven rotor cartridge technology
